Question about "pattern design"
Take the three points. Highlight all three and Group. Right click on the group and select pattern. It looks like you have 1 pattern in two locations. so, describe the pattern and apply to the 1st set. Then repeat the process for the other pattern. You can use the same pattern. Does that make sense?
