[Ri...] Posted February 2, 2023 Share Posted February 2, 2023 Does Zeiss have a camera system that can look at 90° on a radial surface? Something that will fit into bores about Ø80mm+. Similar to this tool. https://sight-pipe.com/crosshatch-gage-handles/ I'm looking into inspecting "Crosshatch" in cylinder bores. Any help is appreciated. Link to comment https://qualityforum.zeiss.com/topic/8706-measuring-quotcrosshatchquot-pattern-in-cylinder-bores/ Share on other sites More sharing options...
[Da...] Posted February 3, 2023 Share Posted February 3, 2023 are you honing the bores? Link to comment https://qualityforum.zeiss.com/topic/8706-measuring-quotcrosshatchquot-pattern-in-cylinder-bores/#findComment-39178 Share on other sites More sharing options...
[Ri...] Posted February 3, 2023 Author Share Posted February 3, 2023 They will be honed when I receive them. Link to comment https://qualityforum.zeiss.com/topic/8706-measuring-quotcrosshatchquot-pattern-in-cylinder-bores/#findComment-39180 Share on other sites More sharing options...
[Da...] Posted February 3, 2023 Share Posted February 3, 2023 I was not aware that Checking the angle was a thing. Link to comment https://qualityforum.zeiss.com/topic/8706-measuring-quotcrosshatchquot-pattern-in-cylinder-bores/#findComment-39182 Share on other sites More sharing options...
[Ri...] Posted February 3, 2023 Author Share Posted February 3, 2023 Please sign in to view this quote. Read up on it, (Nerd Alert) its pretty cool. 👩🏫 Link to comment https://qualityforum.zeiss.com/topic/8706-measuring-quotcrosshatchquot-pattern-in-cylinder-bores/#findComment-39184 Share on other sites More sharing options...
[Da...] Posted February 3, 2023 Share Posted February 3, 2023 Nerdier nerd alert ! You can compute the angle based on the diameter size, the length of stroke, and the RPM ! Math nerd!! 🧑💻 Link to comment https://qualityforum.zeiss.com/topic/8706-measuring-quotcrosshatchquot-pattern-in-cylinder-bores/#findComment-39186 Share on other sites More sharing options...
[Ri...] Posted February 4, 2023 Author Share Posted February 4, 2023 Please sign in to view this quote. Neat... But the customer wants a visual inspection, not a calculation. Link to comment https://qualityforum.zeiss.com/topic/8706-measuring-quotcrosshatchquot-pattern-in-cylinder-bores/#findComment-39188 Share on other sites More sharing options...
