[Sa...] Posted February 2, 2023 Share Posted February 2, 2023 Hello everybody. I started to learn how to program with Calypso not so long ago. My question is, when do I use the different distances (polar 2d, 3d, cartesian, point distance, simple distance) ? Sorry for any spelling/translation mistakes, english isn´t my first language Link to comment https://qualityforum.zeiss.com/topic/8718-the-different-distances/ Share on other sites More sharing options...
[Ma...] Posted February 2, 2023 Share Posted February 2, 2023 It would be helpfull to see documentation ( help files ) - it should describe usage and how to use it. I mostly use caliper distance mostly due ability to choose which alignment i want to use. Next is cartesian for opposing planes - it reports length of perpendicular - difficult is to set it up correctly. I don't use others too much - caliper distance gives you 2D and 3D measuring like polar do. Play with it. Link to comment https://qualityforum.zeiss.com/topic/8718-the-different-distances/#findComment-39280 Share on other sites More sharing options...
[Ma...] Posted February 2, 2023 Share Posted February 2, 2023 In the User Guide in Calypso do a search for "Characteristics for Size - Distance". It has a brief description of each one that may help. Also, as Martin said play with them which will help you get familiar. Link to comment https://qualityforum.zeiss.com/topic/8718-the-different-distances/#findComment-39282 Share on other sites More sharing options...
[Ju...] Posted February 2, 2023 Share Posted February 2, 2023 Be aware that the second feature in the distance characteristic sets the direction of the measurement, so a more stable feature in the second feature selection will give better data. (Point to plane will give better accuracy than plane to point.) Link to comment https://qualityforum.zeiss.com/topic/8718-the-different-distances/#findComment-39284 Share on other sites More sharing options...
[Ma...] Posted February 2, 2023 Share Posted February 2, 2023 Please sign in to view this quote. I think you can not switch it - it will do the same or you can not reverse it. Link to comment https://qualityforum.zeiss.com/topic/8718-the-different-distances/#findComment-39286 Share on other sites More sharing options...
[Ju...] Posted February 2, 2023 Share Posted February 2, 2023 This is where I obtained the information: viewtopic.php?t=4001 Link to comment https://qualityforum.zeiss.com/topic/8718-the-different-distances/#findComment-39288 Share on other sites More sharing options...
[Sa...] Posted February 3, 2023 Author Share Posted February 3, 2023 Please sign in to view this quote. Thank you so much! Unfortunately I don´t have the caliper distance in this Version of Calypso (2015 6.0.04). So I´m going to test the other ones out. 🙂 Link to comment https://qualityforum.zeiss.com/topic/8718-the-different-distances/#findComment-39290 Share on other sites More sharing options...
[ni...] Posted February 3, 2023 Share Posted February 3, 2023 some pdf about cartesian distance and perpen. Have a good readingPerp Const_Plane v Cyl.pdfLNL Distance.pdfPerp vs Cart Dist.pdf Link to comment https://qualityforum.zeiss.com/topic/8718-the-different-distances/#findComment-39292 Share on other sites More sharing options...
