[Sa...] Posted February 2, 2023 Share Posted February 2, 2023 Hello everybody. I started to learn how to program with Calypso not so long ago. My question is, when do I use the different distances (polar 2d, 3d, cartesian, point distance, simple distance) ? Sorry for any spelling/translation mistakes, english isn´t my first language Link to comment Share on other sites More sharing options...
[Ma...] Posted February 2, 2023 Share Posted February 2, 2023 It would be helpfull to see documentation ( help files ) - it should describe usage and how to use it. I mostly use caliper distance mostly due ability to choose which alignment i want to use. Next is cartesian for opposing planes - it reports length of perpendicular - difficult is to set it up correctly. I don't use others too much - caliper distance gives you 2D and 3D measuring like polar do. Play with it. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 2, 2023 Share Posted February 2, 2023 In the User Guide in Calypso do a search for "Characteristics for Size - Distance". It has a brief description of each one that may help. Also, as Martin said play with them which will help you get familiar. Link to comment Share on other sites More sharing options...
[Ju...] Posted February 2, 2023 Share Posted February 2, 2023 Be aware that the second feature in the distance characteristic sets the direction of the measurement, so a more stable feature in the second feature selection will give better data. (Point to plane will give better accuracy than plane to point.) Link to comment Share on other sites More sharing options...
[Ma...] Posted February 2, 2023 Share Posted February 2, 2023 Please sign in to view this quote. I think you can not switch it - it will do the same or you can not reverse it. Link to comment Share on other sites More sharing options...
[Ju...] Posted February 2, 2023 Share Posted February 2, 2023 This is where I obtained the information: viewtopic.php?t=4001 Link to comment Share on other sites More sharing options...
[Sa...] Posted February 3, 2023 Author Share Posted February 3, 2023 Please sign in to view this quote. Thank you so much! Unfortunately I don´t have the caliper distance in this Version of Calypso (2015 6.0.04). So I´m going to test the other ones out. 🙂 Link to comment Share on other sites More sharing options...
[ni...] Posted February 3, 2023 Share Posted February 3, 2023 some pdf about cartesian distance and perpen. Have a good reading Perp Const_Plane v Cyl.pdfFetching info... LNL Distance.pdfFetching info... Perp vs Cart Dist.pdfFetching info... Link to comment Share on other sites More sharing options...
