[Da...] Posted January 23, 2023 Share Posted January 23, 2023 Hello, I am new to CMMs in general, so please keep that in mind when responding. I have a position callout of a threaded hole, and while I understand using a helix path to locate, or using a hole location gage, this thread has a couple oddities. For one, it is a Stub Acme thread. I do not see any options to purchase a hole location gage for stub acme threads. Also, the thread has multiple gaps, so I am not sure how to do a helix path without it hitting a gap. Thanks in advance for any advice. Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/ Share on other sites More sharing options...
[Ri...] Posted January 23, 2023 Share Posted January 23, 2023 How big is this thread? Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/#findComment-39402 Share on other sites More sharing options...
[Da...] Posted January 23, 2023 Author Share Posted January 23, 2023 1.750 - 12 Stub Acme Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/#findComment-39404 Share on other sites More sharing options...
[Du...] Posted January 23, 2023 Share Posted January 23, 2023 what exactly do you mean by multiple gaps. ive had to run quite a few stub acme threads on my machine, could you post a picture of it or the print? Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/#findComment-39406 Share on other sites More sharing options...
[Da...] Posted January 23, 2023 Author Share Posted January 23, 2023 Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/#findComment-39408 Share on other sites More sharing options...
[Ph...] Posted January 23, 2023 Share Posted January 23, 2023 Depending on the accuracy needed ("Cyl. Form Lines", "line scans", "Linear Paths") seem to work well for location. Name will depend on the software version. I use 16-20 pts per thread inch depth and scan slow about .2" in speed, and 8 lines per cylinder. Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/#findComment-39410 Share on other sites More sharing options...
[Du...] Posted January 23, 2023 Share Posted January 23, 2023 ahh, i see now. at this point I don't think you would be able to do a helical path but maybe you could do multiple linear paths down the thread and set your evaluation to inner tangential. i used this a few time with success Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/#findComment-39412 Share on other sites More sharing options...
[Ma...] Posted January 23, 2023 Share Posted January 23, 2023 If you have a rotary table you could construct a cylinder from a number of self centering points or even helical scans between the interruptions. It may also be possible to accomplish this with a miniature start probe without a rotary table. Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/#findComment-39414 Share on other sites More sharing options...
[Gr...] Posted January 31, 2023 Share Posted January 31, 2023 You might try using a cylindrical stylus and points without scanning. This avoids probing between the threads. Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/#findComment-39416 Share on other sites More sharing options...
[Je...] Posted January 31, 2023 Share Posted January 31, 2023 Please sign in to view this quote. Outer Tangential Outer-Tangential will represent and interfacing perfect gage. If measuring as a circle, (Flyscan from VAST Peformance option is made for scenarios like this) measure slow and overlap data. Evaluate as Outer-Tangential to get your minor diameter as measured with a gage pin. Careful with going heavy on filters and outliers as this can easily affect your data. If measuring as a cylinder, use several circle scans in the same manner with as much feature depth as possible. If your diameter is greater than your bore depth between furthest scans, revert to circle feature as the feature type. Axis projection could become an issue due to feature geometry. Link to comment https://qualityforum.zeiss.com/topic/8754-position-of-stub-acme-thread/#findComment-39418 Share on other sites More sharing options...
