Not Reporting Elements
This can be done via the Multiple Report window in the measurement tab.2915_54a89a5ba3a578591ef3c66e193b59e9.jpg
Click the multiple report button, and a pop up window will open-in this window in the upper left is a check box for "multiple reports active", and near the bottom is a check box for "Hide (selected characteristics are not displayed),both of which should be checked for this application(If hide is not checked, marked characteristics will still be displayed).Finally, in the upper right of this window is a button labelled "mark characteristics". 2915_fb18dd6886d2d6a4f0e322f1632d9580.jpg
Select this button and another menu will open, in this menu turn marking to ON for the characteristics you wish to hide.2915_ac6ec52893ac73aabaec82227e982f5a.jpg
