[Cr...] Posted January 30, 2023 Share Posted January 30, 2023 I need to make several Elements to report the Average of the Elements, but I do not want the Elements to be on the Report as well. Is there a way to turn off the Elements when it comes to the report?2675-op10-Side-Rev_BNANATEST PARTSCJF024.pdf Link to comment Share on other sites More sharing options...
[Ke...] Posted January 31, 2023 Share Posted January 31, 2023 This can be done via the Multiple Report window in the measurement tab. Click the multiple report button, and a pop up window will open-in this window in the upper left is a check box for "multiple reports active", and near the bottom is a check box for "Hide (selected characteristics are not displayed),both of which should be checked for this application(If hide is not checked, marked characteristics will still be displayed).Finally, in the upper right of this window is a button labelled "mark characteristics". Select this button and another menu will open, in this menu turn marking to ON for the characteristics you wish to hide. Link to comment Share on other sites More sharing options...
