[Lu...] Posted January 19, 2023 Share Posted January 19, 2023 Guten Mittag zusammen, Die Calypso Software macht für jede Messung eine eigene Ausgabedatei. Kann ich der Software irgendwo sagen dass sie mir z.B. die Messergebnisse von 8 Messungen in die gleiche Datei schreiben soll? Ich benötige das für die Excel Ausgabe und für die DFQ Ausgabe. Im Voraus schonmal vielen Dank Mit Freundlichen Grüßen Luca Müller Link to comment https://qualityforum.zeiss.com/topic/8794-calypso-messwerteausgabe/ Share on other sites More sharing options...
[Ma...] Posted January 19, 2023 Share Posted January 19, 2023 For DFQ it can be modified on "Name for output files" - Q-DAS i believe. Default is at "Documents\Public\Zeiss\CalypsoX.X\workarea\qdas\plan_name" For excel: i didn't succeded with excel ( message to have installed excel ), but i don't see any possible settings to edit path. Link to comment https://qualityforum.zeiss.com/topic/8794-calypso-messwerteausgabe/#findComment-39656 Share on other sites More sharing options...
[Gu...] Posted January 27, 2023 Share Posted January 27, 2023 Merge File: Write results from several measurements in a CSV file. Read the CSV file into EXCEl and then sort the data in EXCEL Use the Merge File in: Resources / Results to File: Table File <on> and Merge File <on> Default output path: C:\Users\Public\Documents\Zeiss\CALYPSO 7.x\workarea\results\ Link to comment https://qualityforum.zeiss.com/topic/8794-calypso-messwerteausgabe/#findComment-39658 Share on other sites More sharing options...
