[Fu...] Posted January 23, 2023 Share Posted January 23, 2023 Long-time reader, first-time poster! Straight up, newbie! I am trying to measure a part with difficulty I can't figure out in Calypso. The drawing calls for a circle in contact with the two 45-degree angles. I need to measure from the symmetry of the 2mm slot to the center of this circle. I am trying to figure out how to make this circle from two 45-degree plans. Any help would be GREAT! See attached drawing 3511- Drawing.pdf Link to comment Share on other sites More sharing options...
[Ün...] Posted January 23, 2023 Share Posted January 23, 2023 Hello, As far as I understand there is no Curve. give this a try Link to comment Share on other sites More sharing options...
[Fu...] Posted January 23, 2023 Author Share Posted January 23, 2023 Thanks, I will give this a try! Link to comment Share on other sites More sharing options...
[Fl...] Posted January 23, 2023 Share Posted January 23, 2023 Hi, try to make Tangents, with 2 lines on the 45 degree plains, you can set up the theoretical diameter and then get a circle as feature. Best regards, Florian Link to comment Share on other sites More sharing options...
[Fu...] Posted January 23, 2023 Author Share Posted January 23, 2023 I tried both ways, and it worked great for me! Thanks for the help! Link to comment Share on other sites More sharing options...
