polygonprofil P3G 10H6
Hello,
I'm measuring a polygon profil P3G (DIN 32711) without curve, so in 3 points and I am aligned on the Ø3 (+theorical rotation) who is machined on the same position machine. the Ød5 is 0.009 mm tolerance.
is it possible to make the planar rotation on the P3G itself ? or how would you do mesure the P3G (Ød5)
thanks
https://qualityforum.zeiss.com/topic/8842-polygonprofil-p3g-10h6/
You can try following version:
- create 3 circles at the position of R2
- open position with the hole pattern (in german it is called Lochbildeinpassung) an select the 3 circles, on this way you get the new coordinate system Einpassung1
- now create a circle in this new coordinate system (in my example i tried with 3 single points)
https://qualityforum.zeiss.com/topic/8842-polygonprofil-p3g-10h6/#findComment-39968
@ Eric :
good, seems to work, i'll make some repeta and see the delta between old method and yours.
@Guillaume :
no curve no scan on my calypso 😠 😠 😠 😠
@Michael
when I define a point at 0 on system Einpassung1, it's like it is actualy at 0 on Base system !! don't work like I want.
other question, how do you make three circle (or point) with one ony element --Punk1(3)--
Thx
https://qualityforum.zeiss.com/topic/8842-polygonprofil-p3g-10h6/#findComment-39970
Also, if it doesn't need to be aligned to the OD, (it's a profile with no Datums, or only 1 Datum) you could consider aligning to itself using a 3d Best Fit Alignment. Use points from the Profile for the Alignment, and check your profile points to the alignment. It works pretty well.
https://qualityforum.zeiss.com/topic/8842-polygonprofil-p3g-10h6/#findComment-39976
