How do I change report units to inches?
Hello. How do I change the reported units in the "characteristic table with statistics" template (or any template for that matter) from metric to inches? The associated measurement plan in Calypso is already in inches, but I cannot get PiWeb to output in inches.
I have a general setting within PiWeb Reporting Plus to output to inches, but this doesn't appear to be working (see attached).
I have the latest version of Calypso (7.4) and PiWeb Reporting Plus (8.2.5).
Jeff, I pretty green with PiWeb. But after you change your unit settings and hit "OK" are you then saving the PiWeb Designer page before closing? Also this template will change the units when new results are supplied with different units. I then have to repeat the settings. If anyone knows how to have PiWeb retain these units without having to reset each time units are changed in Calypso, it would be much appreciated.
  • 1 month later...
Output of the units in the report, conversion of the units (mm/inch, µm, µinch, deg, rad...) will officially come with CALYPSO 2023 and the next version of the CALYPSO reports.
One have to acivate "Convert into output unit"
Preview CALYPSO 2023 units in report:
