[To...] Posted December 6, 2022 Share Posted December 6, 2022 Picture below is for a functional gage use in mfg process. Due to the length of the Datum A feature, position results at the other end can be quite unstable. Unlike a shaft with a bearing journal on each end, designated as A and B (A-B), I don't see creating a datum structure like that. Possibly changing datum A to the larger, longer diameter??? How would you change the dimensioning in order to make the inspection more repeatable yet still produce an accurate functional gage? All 3 diameters are used but I don't know how much of the larger diameter is used. I assume a portion of the larger diameter is merely a handle.pin gage.jpg Link to comment Share on other sites More sharing options...
[Ma...] Posted December 6, 2022 Share Posted December 6, 2022 Why can not be the longest cylinder as main base? Everything have M on itself and on A too. Link to comment Share on other sites More sharing options...
[Da...] Posted December 6, 2022 Share Posted December 6, 2022 Seeing that everything is on the same center line I would use the largest cylinder as datum -A- and then use run out for the small cylinder instead of position. Link to comment Share on other sites More sharing options...
[Ke...] Posted December 6, 2022 Share Posted December 6, 2022 I would not want to make any changes/suggestions (as the inspector) without knowing the exact function/application. ...based on just the info I have in front of me, I would consider making the second smallest diameter (between A & B) Datum C, and checking the position of the largest diameter to Position to A-C Link to comment Share on other sites More sharing options...
[To...] Posted December 6, 2022 Author Share Posted December 6, 2022 Please sign in to view this quote. Functional fit of firing pin hole on bolt action rifleScreenshot 2022-12-06 145342.jpg Link to comment Share on other sites More sharing options...
[Ma...] Posted December 7, 2022 Share Posted December 7, 2022 Thx for sharing Tom. The longest cylinder will have bigger tolerances due to usage and friction, so as Keith suggested - i would take middle one - crucial on this part will be the smallest cylinder, but all fitting will be upon middle one. But we are talking about really tight tolerances right? Link to comment Share on other sites More sharing options...
[Ke...] Posted December 7, 2022 Share Posted December 7, 2022 Very cool. Based on the application, I would lean toward this (attached) It looks like only a small area of the smallest diameter (currently Datum A) is a functional area; so you may want to consider defining a target area to evaluate to New Datum A For the largest diameter, it looks like the full length is used after the smallest diameter has fully engaged; so my preferred datums for evaluating that would be the A-C co-datums. Link to comment Share on other sites More sharing options...
[Ro...] Posted December 7, 2022 Share Posted December 7, 2022 Since all 3 diameters simultaneously fit at the same time on the same axis, I would use all 3 diameters as the alignment. A-B-C as co-datums for the primary. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 15, 2022 Share Posted December 15, 2022 I've worked on fire arms in the past. This is the typical measurement back then. Hope this helpsScreenshot 2022-12-06 145342.jpg Link to comment Share on other sites More sharing options...
