Datum Reference Frame -S
Print was made in 2004.
The way I see it is the "S" with a circle around it is for "regardless of feature size" so, why put -S beside it?
Definitely an unusual one.
They already have the circled S for RFS - seems redundant.
Unless you have a Datum S on your drawing and they are trying to imply K-S combo datum ??
"Unless you have a Datum S on your drawing and they are trying to imply K-S combo datum ??"
Oh I see what Owen was saying in the original post about "-S" instead of the circled S. I concur with this take, but I am sure Owen will chime in to say there is no datum S 🤣
BINGO!
Yes, there is a Datum S.
It's a qualifying pad for initial machining that has no effect on fit/form & function of the unit in any application so, I'm not sure why they'd do that. .
If they put the circled "S" (RFS) after the -S , I would have recognized it much easier, as that how it is commonly called out.
Since -S is an unusual datum perhaps "RFS" is not even an option for that datum ...
Glad you figured it out ...
The chicken head is the way this undisclosed company use to denote certain characteristics as important to fit/form/function, assembly, critical/major/minor, etc. Like some use half-filled, solid-filled, quarter-filled circles, etc.
No matter how hard they try, Standardizing GD&T is like getting the whole world to speak the same language, it'll never happen completely.
Anywho, much thanks to Chris Rotolo and others helping me get this figured out.
Sometimes I'll post a question here not because I can't figure it out but, because I don't have the time to think-about it working on so many things at the same time. This year puts a whole new meaning on multi-tasking as I can now laugh, cough, fart, sneeze and pee all at the same time 🙄
