Betriebsstunden auslesen-möglich?
There is a software made for interfacing and monitoring Zeiss CMMs called "CMMobserver".
Outside CMMobserver, I have seen some "clever" methods using PC utilization programs but the closest has been using PCM to create a file that logs time between inspection_start_pcm.txt and report_end_pcm.txt and adding it up for the day. This has been the closest to CMMobserver I have seen but it is not a small task to create that properly as that had its own set of difficulties to overcome and in the end was not nearly as useful or informative.
https://www.zeiss.com/metrology/product ... mmobserver
This link may be available to US customers only. My apologies to our international customers if this link is not operational.
