[Ro...] Posted November 21, 2022 Share Posted November 21, 2022 Hallo an alle Leser. Weiß jemand von euch wie man bei einer Messmaschine z.b. Contura G2 die Betriebsstunden auslesen kann. Vielen Dank für eure Infos. Link to comment Share on other sites More sharing options...
[Je...] Posted November 21, 2022 Share Posted November 21, 2022 There is a software made for interfacing and monitoring Zeiss CMMs called "CMMobserver". Outside CMMobserver, I have seen some "clever" methods using PC utilization programs but the closest has been using PCM to create a file that logs time between inspection_start_pcm.txt and report_end_pcm.txt and adding it up for the day. This has been the closest to CMMobserver I have seen but it is not a small task to create that properly as that had its own set of difficulties to overcome and in the end was not nearly as useful or informative. https://www.zeiss.com/metrology/product ... mmobserver This link may be available to US customers only. My apologies to our international customers if this link is not operational. Link to comment Share on other sites More sharing options...
[Ro...] Posted November 22, 2022 Author Share Posted November 22, 2022 Vielen Dank für Ihre Antwort Link to comment Share on other sites More sharing options...
