[Ro...] Posted April 21, 2020 Share Posted April 21, 2020 Can I add a Cad-Presentation into a PiWeb report (not full page)? I am looking at reporting the flatness with the cad model for reference. Thanks for any help. -Bob Link to comment Share on other sites More sharing options...
[24...] Posted April 21, 2020 Share Posted April 21, 2020 Yes, if you have a CAD presentation in your measurement plan and you are using the StandardProtocol.ptx, you can view the expanded row template by clicking on the form plot in the ribbon along the top of your report (looks like a small donut) and click Detailed. Clicking on the CAD presentation preview will show a larger version. Link to comment Share on other sites More sharing options...
[Ro...] Posted April 22, 2020 Author Share Posted April 22, 2020 Thanks for the info. Is there a way to automatically save the detailed report in pdf? Link to comment Share on other sites More sharing options...
[24...] Posted April 22, 2020 Share Posted April 22, 2020 You can go to Resources > Name for Output files > and choose an automatic naming convention for either that specific measurement plan, or all measurement plans. You'll want to click 'X' name of output file variable if you want to use variables like date, time, part # to format the filename. Now, I know that you can PDF the PiWeb report by selecting PDF File PiWeb reporting and configuring the export there. However I think that the CAD presentation graphic still is produced in an older style display window, so I think you will also need to configure an export for PDF File Graphics as well. In the dialog box it will show you a running list of items you'll be naming or saving automatically, so you should have 2 line items building in the white portion of the box at the bottom. I could be wrong on the second part, give it a try and see what produces your desired result. Link to comment Share on other sites More sharing options...
[Da...] Posted October 20, 2022 Share Posted October 20, 2022 I'm using 2022 and the CAD presentation will output using the PiWeb standard protocol output from the multiple report window with plot output turned on. And as previously mentioned, you can turn on the automatic PDF output and specify the file naming criteria. Link to comment Share on other sites More sharing options...
[SH...] Posted November 13, 2022 Share Posted November 13, 2022 Please sign in to view this quote. But, how can I control the location it is being saved.. Link to comment Share on other sites More sharing options...
[Da...] Posted November 16, 2022 Share Posted November 16, 2022 There's two ways: 1. Go to Extras -> Settings -> Environment and select the "Paths" tab. There you can change "Default Path for Result Files" 2. Go to Prepare -> Name for output files -> ... for this/all Measurement Plan(s) Select "PDF file PiWeb reporting" under Output file and there you can set path and file name from report header for example. Link to comment Share on other sites More sharing options...
[Je...] Posted November 17, 2022 Share Posted November 17, 2022 If you are outputting multiple PDF files and would like them to all be created as one PDF, you can enable "PDF_ALL" in the name of output files options. This requires an extra step which is the download and installation of Ghostscript however. Calypso will execute the ghostscript command and merge all PDFs created in that inspection plan into one PDF file. The others will still exist unless you write PCM to delete them or send them to a directory that auto-deletes via a Windows command. This can be found at link below. gs925w32.exe is the file required. https://github.com/ArtifexSoftware/ghos ... /tag/gs925 Link to comment Share on other sites More sharing options...
[To...] Posted May 21 Share Posted May 21 When creating a custom plot protocol template, what is the protocol to show a CAD Presentation? Link to comment Share on other sites More sharing options...
[Ri...] Posted May 21 Share Posted May 21 CAD Presentation is just a screenshot, so typically I use the Dynamic Image - then set the Source to Additional data: measured value Link to comment Share on other sites More sharing options...
[To...] Posted May 21 Share Posted May 21 Please sign in to view this username. Thanks, I will give that a go. Link to comment Share on other sites More sharing options...
