Get Data from Roundness Filter with PCM
I'm trying to get the following data from a Roundness characteristic with a low-pass Gauss filter. The feature being evaluated is a circle. Using Calypso 5.6
1) Filter Type
2) Filter Method
3) Filter UPR
4) Number of scan points
5) Min deviation from filtered points and its index
6) Max deviation from filtered points and its index
Is this possible? Any help is appreciated!
https://qualityforum.zeiss.com/topic/9260-get-data-from-roundness-filter-with-pcm/
PCM or not, I'm just looking for the correct syntax to access the data. I'm sure it's possible, I just don't know where to start. The getActual().result.filter functions don't have anything on the number of points.
I'm looking to output the data to a text file so PiWeb is not an option at this time.
[/quote]
[/quote]
The getActual().result.filter functions is what I would suggest for most items, Further research shows you can use setFilter but not getFilter...hmm..
Regarding the actual point numbers, those might be tricky, however you might use a minimum coordinate/maximum coordinate characteristic - you could recall polar position points with a LOOP and find the smallest/largest RAD value, etc.
that's about all I got off the top of my head, I'll research a bit more when I can.
good luck.
Update, after playing around I can get the number of points after the filter is applied with:
getActual("Circle1").numberOfPoints
I can also get the total number of points (unfiltered) and then loop through those points getting the X,Y,Z values with:
ptlist=getActual("Circle1").points.vectors
for i = 1 to ptlist.size
ptx = getParameterNamed(ptlist,i).x
pty = getParameterNamed(ptlist,i).y
ptz = getParameterNamed(ptlist,i).z
next i
This method is so close, but the problem is I need to loop through the filtered points, not all of them. There has got to be a way to pull the filtered points data from the feature.
Anyone know?
He,
put the code below inside postparameter of the feature.
Output will be send to the display-window.
Have fun 🤣
Dosn't work at characteristics 😮
Code: CALYPSO 6.20 runs also 7.40
display("#displayCLOSE")
display("#displayON")
feature = getNominal().testPlanGeometry.identifier
display("Feature")
display("---- ---- ---- ---- ----")
display(feature)
display("EvalMethod = ", getActual(feature).result.evalType)
display("NumberOfPoints = ", getActual(feature).numberOfPoints)
display("Form = ", getActual(feature).form.decimalString)
display("MinIndex = ", getActual(feature).result.indexOfMinDev)
display("MinDev = ", getActual(feature).minDev.decimalString)
display("MaxIndex = ", getActual(feature).result.indexOfMaxDev)
display("MaxDev = ", getActual(feature).maxDev.decimalString)
display("Sigma = ", getActual(feature).sigma.decimalString)
FilterType = getActual(feature).result.filter.method
if FilterType == "waves"
display()
display("Wave Filter ")
display("FilterActive = ", getActual(feature).result.filter.filter)
display("FilterType = ", getActual(feature).result.filter.type)
display("FilterKind = ", getActual(feature).result.filter.kindOfPass)
display("FilterPercentage = ", getActual(feature).result.filter.percentage)
display("NoOfWaves = ", getActual(feature).result.filter.nbOfWaves)
display("NoOfWavesTo = ", getActual(feature).result.filter.nbOfWavesTo)
endif
if FilterType == "lambda"
display()
display("Lambda Filter ")
display("WaveLength = ", getActual(feature).result.filter.waveLength)
display("WaveLengthTo = ", getActual(feature).result.filter.waveLengthTo)
endif
display()
display("Outlier ")
lable = getActual(feature).geometry
display("Type = ", lable)
if lable == "curve"
display("OutlierActive = ", getActual(feature).outlier.mode)
display("OutlierCompensation = ", getActual(feature).outlier.compensation)
display("OutlierDocumentation = ", getActual(feature).outlier.documentation)
display("OutlierInside = ", getActual(feature).outlier.factorInside)
display("OutlierOutside = ", getActual(feature).outlier.factorOutside)
display("OutlierMaskmode = ", getActual(feature).outlier.maskMode)
display("OutlierMode = ", getActual(feature).outlier.mode)
display("OutlierNeighbours = ", getActual(feature).outlier.nbOfNeighbours)
else
display("OutlierActive = ", getActual(feature).result.outlier.mode)
display("OutlierCompensation = ", getActual(feature).result.outlier.compensation)
display("OutlierDocumentation = ", getActual(feature).result.outlier.documentation)
display("OutlierInside = ", getActual(feature).result.outlier.factorInside)
display("OutlierOutside = ", getActual(feature).result.outlier.factorOutside)
display("OutlierMaskmode = ", getActual(feature).result.outlier.maskMode)
display("OutlierMode = ", getActual(feature).result.outlier.mode)
display("OutlierNeighbours = ", getActual(feature).result.outlier.nbOfNeighbours)
endif
If you want the filtered points you can use the command writeActualsToFile()
The downside is that that will give you a file (duh).
But something like this:
writeActualsToFile("characteristic name",true,"alignment 1","C:\temp\points.txt")
ListWithAllFilteredPoints = readListFile("C:\temp\points.txt")
for i = 1 to ListWithAllFilteredPoints.size
row = getParameterNamed(ListWithAllFilteredPoints,i)
display(row)
next i
This will go through all the points in the file and print them in the display-window. Of course you do something else with them. Whatever you need to.
All the points that has a status other than 0 is masked for some reason (outlier, masking in the start or end etc.)
Thanks for the response! This was a great idea and works well except it writes all points.
However, this led me to the writeActualsToVDA() function which outputs only the filtered points, albeit in VDA format but something I can work with nonetheless.
I think I'm going to run with it because my brain hurts and this works. Thanks all for the help!
