Minor Annoyance - Slots
Why doesnt Calypso offer The center to center distance on Slots?
The only option i have is the overall length.
So when dealing with callouts like this i have to add 2 half circles and do a distance between, effectively doubling the time it takes to measure the slot.
Or is there another way? is there something i have overlooked?
https://qualityforum.zeiss.com/topic/9274-minor-annoyance-slots/
I have one almost just like this. I measure it with curve, then use lasso to select each circle. This method really isn't that accurate though. Getting good center points with half circles is sketchy at best. The only good solution I have found is to convince design team to switch to a profile measurement. But we have design control in house so I understand this isn't an option for everyone.
https://qualityforum.zeiss.com/topic/9274-minor-annoyance-slots/#findComment-42650
Yes, that's the way to do it, just pointing out that it would be nice if they added a check-box to report the diameters like Tom mentioned or hell, even an option to report potential taper. I'm fairly sure I submitted a request for the option many years ago.
All said though, there have many, many improvements over the years and I'm sure they will continue. Can't make everything perfect of they wouldn't be able to promote any more updates: 🤣
https://qualityforum.zeiss.com/topic/9274-minor-annoyance-slots/#findComment-42660
  • 1 month later...
Last time I tried, you could do the formula for the first feature ("Slot 1), and the copy and paste the Result Element for as many slots as you need, and then change the slot # in the formula without actually right clicking and selecting Formula... a small time saver
https://qualityforum.zeiss.com/topic/9274-minor-annoyance-slots/#findComment-42666
What I just tried and seemed to work is :
If you are simply using "Slot 1" Expansion A - Expansion B, etc.
Pattern your slot measurement (66x).
Add LOOP to your results element, right click insert start 1, end 66.
Worked for me, I verified the looped results to individual calculations.
Y.M.M.V. - Good luck.
https://qualityforum.zeiss.com/topic/9274-minor-annoyance-slots/#findComment-42670
