MMB.... again
Tom,
Just checked, and best fit whether using "A + C" or "A + A + C" does not allow MMC(MMB) for -C- rotation. I know position has allowed MMC of symmetry planes for me in the past.
What I would do in this case is create a theoretical circle whose geometry matches the symmetry plane, make sure ID/OD for MMC, etc. and diameter will be the length of C, etc... I've done this quite a bit in the past. I think there is an old guide somewhere from Ellison, etc.
Good luck !
EDIT : found it.... not my doc just sharing ...
Also this shows MMC of the slot itself which you should now be able to do with Symmetry Plane, however it is the same idea for a slot as a tertiary.
True Position Slot with MMC.pdf
