[Ma...] Posted April 21, 2022 Share Posted April 21, 2022 Guten Morgen, gibt es eine Möglichkeit, als normaler Anwender, den Firmwarestand der C99 Steuerung anzeigen zu lassen? Danke. Link to comment https://qualityforum.zeiss.com/topic/9358-steuerung-c99-firmware/ Share on other sites More sharing options...
[He...] Posted April 21, 2022 Share Posted April 21, 2022 Please sign in to view this quote. Hallo @Marcus Ziegelmüller. Die einfachste Möglichkeit den Firmwarestand zu betrachten ist es das Smart Services Dashboard zu benutzen. Unter dem Punkt "Allgemeine Daten" sind sowohl der Typ der Steuerung, die aktuelle Firmware Version und die Firmware Version des Bedienpults angegeben. Hier ein Link zur Info. https://www.zeiss.at/messtechnik/servic ... itaet.html Hoffe das hilft, beste Grüße Link to comment https://qualityforum.zeiss.com/topic/9358-steuerung-c99-firmware/#findComment-43362 Share on other sites More sharing options...
[Fa...] Posted October 19, 2022 Share Posted October 19, 2022 Please sign in to view this quote. Hallo Marcus, wenn du ein Bedienpult BP26_SE hast (das mit einem Display), dann wird dir die aktuelle Firmware angezeigt wenn du die KMG startest. Link to comment https://qualityforum.zeiss.com/topic/9358-steuerung-c99-firmware/#findComment-43364 Share on other sites More sharing options...
[Ke...] Posted October 19, 2022 Share Posted October 19, 2022 Apologies as I am only capable in English. I will also add a google translated version at the bottom of this. This information, and other useful information, can be accessed via the joystick box, however the information can also be obtained through Calypso relatively easily. Do not do this while the machine is running, as it will treat it as an error and stop. With any program open, press Ctrl+Y. This is the user interrupt, and will open a menu. In that menu is the option for an Error Report, which will have a section showing the firmware. Von Google Translate Diese Informationen und andere nützliche Informationen können über die Joystick-Box abgerufen werden, die Informationen können jedoch auch relativ einfach über Calypso abgerufen werden. Tun Sie dies nicht, während die Maschine läuft, da sie dies als Fehler behandelt und stoppt. Drücken Sie bei geöffnetem Programm Strg+Y. Dies ist der Benutzer-Interrupt und öffnet ein Menü. In diesem Menü befindet sich die Option für einen Fehlerbericht, der einen Abschnitt mit der Firmware enthält.CtrlY.pngErrorReportInfo.png Link to comment https://qualityforum.zeiss.com/topic/9358-steuerung-c99-firmware/#findComment-43366 Share on other sites More sharing options...
