Calypso vs MCOSMOS
Hey guys,
I just did a demo for a potential customer that seems to think they like MCOSMOS better. Does anyone have any experience with MCOSMOS and can comment about the pros and cons as it relates to Calypso?
They don't want Free Form/Curves because of cost and claim MCOSMOS handled the demo part with 2 Surface Profiles much easier. There were 144 individual cylinders and planes making up the 2 profile surfaces. I did it with 2 curves and did line profile as the DRF was fully constrained.
https://qualityforum.zeiss.com/topic/9412-calypso-vs-mcosmos/
Hey Tom. I haven't used MCOSMOS, so I can't comment, but I had two questions while reading this.
1. In your DRF, did you just pick any two opposing cylinders to serve as Datum B, or did you construct something else for the Datum feature?
2. For the position requirement on the print you provided, does Datum C constrain anything for this characteristic? I realize one degree of translation is available for Datum C, but does this constraint affect the position characteristic, since the controlled cylinders' axis are perp. to Datum C?
https://qualityforum.zeiss.com/topic/9412-calypso-vs-mcosmos/#findComment-43720
The datum feature simulator will be a flat plate,upon which a centre bunk for locating and another long pin for orientation, so as you mentioned datum c only stop translate in along z axis.. it should be perpendicular to Aand C.
He might use a single cylinder or a 3D line then intersect with C ,will get a point , use that point for clocking...
https://qualityforum.zeiss.com/topic/9412-calypso-vs-mcosmos/#findComment-43722
1. During the demo, they admitted that the B notation was incorrect. They just made up this drawing for the demo. To keep it simple and fast, I did a 3d line between 2 inline circles.
2. Technically, Datum C doesn't do anything but control the location of the tolerance zone along the axis of A. I'm guessing there is not noticeable difference if C is used or not.
https://qualityforum.zeiss.com/topic/9412-calypso-vs-mcosmos/#findComment-43736
