[Be...] Posted March 31, 2022 Share Posted March 31, 2022 Good afternoon all, I working on a program now. the model has two components(top & bottom ring). We measure all the feature from the top ring and we need to remove the top ring to have access to the feature between the two ring. Can we hide the top rings haft way tough the program?. Can someone let me know if this is possible.. Thank you in advance for all your help. Link to comment https://qualityforum.zeiss.com/topic/9418-two-model-view-in-the-same-program/ Share on other sites More sharing options...
[Dy...] Posted March 31, 2022 Share Posted March 31, 2022 CAD- VIEW - CLIPPING PLANE adjust according to you needs in XYZ Link to comment https://qualityforum.zeiss.com/topic/9418-two-model-view-in-the-same-program/#findComment-43762 Share on other sites More sharing options...
[Cl...] Posted March 31, 2022 Share Posted March 31, 2022 If you have PCM, you can swap out the two models with a prompt. I am not 100% sure of the exact code, but there are several programmers on the forum that are well versed in PCM. Link to comment https://qualityforum.zeiss.com/topic/9418-two-model-view-in-the-same-program/#findComment-43764 Share on other sites More sharing options...
[Dy...] Posted March 31, 2022 Share Posted March 31, 2022 is this just for programming to get to those features? Link to comment https://qualityforum.zeiss.com/topic/9418-two-model-view-in-the-same-program/#findComment-43766 Share on other sites More sharing options...
[Cl...] Posted March 31, 2022 Share Posted March 31, 2022 Do you have PCM (Parameter controlled Measurement)? Link to comment https://qualityforum.zeiss.com/topic/9418-two-model-view-in-the-same-program/#findComment-43768 Share on other sites More sharing options...
[Be...] Posted March 31, 2022 Author Share Posted March 31, 2022 I don’t have PCM Link to comment https://qualityforum.zeiss.com/topic/9418-two-model-view-in-the-same-program/#findComment-43770 Share on other sites More sharing options...
[No...] Posted April 1, 2022 Share Posted April 1, 2022 For programming you can make the top ring invisible (assuming it's a CAD assembly) by removing the checkmark in front of it in the hierarchy. During the actual run you don't need to modify the model at all. Just insert a programmed stop in the strategy of the last feature of the top ring, so the operator can remove it before continuing the run. Make sure to run by feature list. Link to comment https://qualityforum.zeiss.com/topic/9418-two-model-view-in-the-same-program/#findComment-43772 Share on other sites More sharing options...
[Be...] Posted October 11, 2022 Author Share Posted October 11, 2022 Anyone know what PCM Code I have to use to make a swish in between the model. Link to comment https://qualityforum.zeiss.com/topic/9418-two-model-view-in-the-same-program/#findComment-43774 Share on other sites More sharing options...
