[Er...] Posted September 27, 2022 Share Posted September 27, 2022 After a program has ran and the piweb report is generated, it is only showing nominals for both actuals and nominals. Anyone else ever have this problem? Link to comment https://qualityforum.zeiss.com/topic/9420-piweb-reporting-issue/ Share on other sites More sharing options...
[Je...] Posted October 10, 2022 Share Posted October 10, 2022 Please sign in to view this quote. . This just happened to me today. The plots report has images and values but the standard report does not show actuals. Other items such as the word "Calypso" at the top of the page are also missing. What in the world is causing this? . blank_report_no_actuals_showing.pdf Link to comment https://qualityforum.zeiss.com/topic/9420-piweb-reporting-issue/#findComment-43778 Share on other sites More sharing options...
[Er...] Posted October 10, 2022 Author Share Posted October 10, 2022 Please sign in to view this quote. I did find that if you click the button in the top right corner of the page to fetch the data, and save it, it will populate the report correctly which then you can either save or hit cancel and print out. I just don't know why all of a sudden it when populate the data after the part run. Link to comment https://qualityforum.zeiss.com/topic/9420-piweb-reporting-issue/#findComment-43780 Share on other sites More sharing options...
[Je...] Posted October 11, 2022 Share Posted October 11, 2022 Please sign in to view this quote. Thank you very much for sharing this, Eric. Unfortunately, this didn't work so well in my case. I opened a support ticket, so we'll see... Link to comment https://qualityforum.zeiss.com/topic/9420-piweb-reporting-issue/#findComment-43782 Share on other sites More sharing options...
