Custom probe styli
ITP is my goto.
They initially responded with "is 1.4mm close enough"... and no. no it isn't. Why would I be so specific as to request a diameter at 4 decimal places, if I didn't need to? 🤣
They are now checking with their supplier 🙄
https://qualityforum.zeiss.com/topic/9446-custom-probe-styli/#findComment-43924
I understand you may have a specific need for a stylus diameter of 1.1574 to simulate a m.o.w. result and that is a valid measurement method for what you are likely trying to acheive but is there a specific reason you could not use an off-the-shelf 1mm and create a formula in your reporting (read: Result Element or offset Curve points) to give you the proper reported size? I've done this many many times. It isn't feasible to create a custom stylus for every different thread pitch m.o.w. requirement.
Measure your features and create an offset in the result element that adds the difference between measuring with the current stylus "getProbe("stylus","config").diameter vs an ideal 1.1574. (be sure to use the actual value instead of static value in case someone ever changes the stylus and its off by a small amount). This is especially true when going up to the 3-5mm range and down to the 0.3-0.6 range. Styli get swapped all the time for whatever is available when something breaks.
https://qualityforum.zeiss.com/topic/9446-custom-probe-styli/#findComment-43932
A million ways to skin the cat but, because pitch is often considered a theoretical dimension and often difficult to get CMM vs hand gauge matches (especially on odd-tooth gears and over 3-pin thread measurement) don't forget that you can also use the result element to ask the dimensions measured with gauges (before the program closes) and print it out. Nobody likes introducing a hand check because it takes time and the cmm is setting idle until completed but, sometimes it's necessary.
https://qualityforum.zeiss.com/topic/9446-custom-probe-styli/#findComment-43936
