[Ar...] Posted August 8, 2022 Share Posted August 8, 2022 Hello, I have tried to get printheaders to work a while, but I was able to change only "cphead" and it didn't worked in ASCII printout. only default ASCII printout prints txt file with all data, but not with pallet number etc. I need. Is there any possibility to add pallet number, or cavity number in these headers? Or modificate it in anyway? I do not seem to get it print any different header, no matter how I try to modificate header graphics. Or am I modificating wrong things? Is there some file that contains information what get printed on ASCII printout?? I do get my filename correct Link to comment https://qualityforum.zeiss.com/topic/9452-problem-with-ascii-printout/ Share on other sites More sharing options...
[Je...] Posted October 4, 2022 Share Posted October 4, 2022 Resources > Design Custom Report > Report Header Compact Printout This opens the editor. File > Open > C:\Users\Public\Documents\Zeiss\CALYPSO\protocol\protform\default\cphead.gra (create a copy of this file first before saving over it btw "cphead_bak.gra") Add the header fields you wish to include. Save the file as cphead.gra Link to comment https://qualityforum.zeiss.com/topic/9452-problem-with-ascii-printout/#findComment-43956 Share on other sites More sharing options...
[Ar...] Posted October 5, 2022 Author Share Posted October 5, 2022 Hello, Thanks for taking time to answer. I may not been clear enough what I wanted and what is already working. I do get pallet number to compact print, but it do not print it to ASCII txt file. So when I look at compact print it's okay, but when I open ASCII txt file there is no pallet number or any of the modified header data. I did get workaround for this though. I take text element and put all information to there. It seems to print on ASCI txt file. Link to comment https://qualityforum.zeiss.com/topic/9452-problem-with-ascii-printout/#findComment-43958 Share on other sites More sharing options...
