[Lu...] Posted September 25, 2022 Share Posted September 25, 2022 Hi everybody, Is anybody here who use special element HOLOS? Please. Can you tell me or show me. How do I automatically change the stylus system in special elemen Holos? Because i must change it manually and that is no good for me. Thanks. Link to comment Share on other sites More sharing options...
[Lu...] Posted September 27, 2022 Author Share Posted September 27, 2022 Nobody help me with my problem? Link to comment Share on other sites More sharing options...
[Ju...] Posted September 27, 2022 Share Posted September 27, 2022 Screenshots of your software would help. I have never used HOLOS ikon, but it might be a similar process as Calypso if it is also a Zeiss product. Link to comment Share on other sites More sharing options...
[Lu...] Posted September 27, 2022 Author Share Posted September 27, 2022 It is a special element in Calypso. It is used to go to the HOLOS program. Link to comment Share on other sites More sharing options...
[Ju...] Posted September 27, 2022 Share Posted September 27, 2022 The stylus system will be set in the Clearance Data for the feature. Then Calypso should retrieve the specified stylus system from the rack.Holos.jpg Link to comment Share on other sites More sharing options...
[Lu...] Posted September 27, 2022 Author Share Posted September 27, 2022 yes i did that but the stylus system didn't change Link to comment Share on other sites More sharing options...
[Ju...] Posted September 27, 2022 Share Posted September 27, 2022 So you set it to the desired stylus system, but Calypso didn't retrieve it from the rack? Link to comment Share on other sites More sharing options...
[Lu...] Posted September 27, 2022 Author Share Posted September 27, 2022 Yes I also use it in other programs and it works there. But I don't know why? What am I doing wrong? Link to comment Share on other sites More sharing options...
[Ju...] Posted September 27, 2022 Share Posted September 27, 2022 Again, I've never used Holos, but some things to look for are to make sure you specified the correct stylus system and make sure that stylus system is assigned in the rack. Is the program having issues written in the same version of Calypso as the version you are currently running? Do you have the latest service packs installed? Link to comment Share on other sites More sharing options...
[Lu...] Posted September 27, 2022 Author Share Posted September 27, 2022 I think this program was made in an older version Calypso. Link to comment Share on other sites More sharing options...
[To...] Posted September 27, 2022 Share Posted September 27, 2022 I don't anything about HOLOS but is there a characteristic associated with this feature? If not, Calypso will not run the feature. Link to comment Share on other sites More sharing options...
[Lu...] Posted September 28, 2022 Author Share Posted September 28, 2022 characteristic HOLOSholos.JPG Link to comment Share on other sites More sharing options...
[To...] Posted September 28, 2022 Share Posted September 28, 2022 Please sign in to view this quote. Interesting. HOLOS item is found under "Additional Features" and contains a Strategy button yet it is a Characteristic. As I mentioned, I know nothing about HOLOS. Sorry about that. Link to comment Share on other sites More sharing options...
[Ju...] Posted September 28, 2022 Share Posted September 28, 2022 Apparently, it's akin to Gear Pro, so more help might be available in the Gear Pro section of the forum.Holos2.jpg Link to comment Share on other sites More sharing options...
[Lu...] Posted September 28, 2022 Author Share Posted September 28, 2022 It would be better to find someone who uses this element. You know someone? Link to comment Share on other sites More sharing options...
[SH...] Posted September 28, 2022 Share Posted September 28, 2022 This software is being used in which field?? Link to comment Share on other sites More sharing options...
[Lu...] Posted September 28, 2022 Author Share Posted September 28, 2022 http://www.tqscorp.com/docs/zeiss/software/5.pdf Link to comment Share on other sites More sharing options...
[Ju...] Posted September 28, 2022 Share Posted September 28, 2022 At the start screen, do you have your Selection set to All Characteristics? Link to comment Share on other sites More sharing options...
[Lu...] Posted September 29, 2022 Author Share Posted September 29, 2022 yes of course Link to comment Share on other sites More sharing options...
[Ju...] Posted September 29, 2022 Share Posted September 29, 2022 Not to be demeaning, but often times the solution to an issue in Calypso is just something simple like that. When troubleshooting, I have found it best to start at the very beginning. ("Do I have the correct measurement plan open?" and go from there) Link to comment Share on other sites More sharing options...
[Lu...] Posted September 29, 2022 Author Share Posted September 29, 2022 I also think it will be something simple. Something to click on. but where is it? 🙂 🙂 but thank you for your help Link to comment Share on other sites More sharing options...
[To...] Posted September 29, 2022 Share Posted September 29, 2022 What happens when you right-click on the Holos icon and select Execute? Link to comment Share on other sites More sharing options...
[Lu...] Posted September 29, 2022 Author Share Posted September 29, 2022 it goes into the HOLOS program ......and then the holos program stops because it doesn't have the correct stylus system... Link to comment Share on other sites More sharing options...
[Ju...] Posted September 29, 2022 Share Posted September 29, 2022 Could you create a characteristic that uses a feature measured with the correct stylus system before the HOLOS characteristic? Link to comment Share on other sites More sharing options...
[Lu...] Posted September 29, 2022 Author Share Posted September 29, 2022 I placing a space point with correct stylus system in front of the HOLOS characteristic Link to comment Share on other sites More sharing options...
