[As...] Posted May 15, 2022 Share Posted May 15, 2022 Hello, I want to analyze a compact tension test result of DIC on rock samples. when I set calibrating scale and implement the surface component the resultant strain map is not satisfactory. my tested specimen includes a crack. I think different distribution of strain field are expected around the crack and especially at the crack tip, but my strain plots does not include them. I attached one frame of my result. is there any solution for this? or is there any missed procedure? thanks Link to comment Share on other sites More sharing options...
[Th...] Posted May 16, 2022 Share Posted May 16, 2022 (edited) Hi, your expectations are right - there should be some strain values at least over the crack. How does your stage 1 look like? Is it already cracked there or is it snapped from the unloaded specimen? How does the displacement field (check for Displacement or DisplacementX) look like? Anyway - for this kind of crack an EpsilonX or MajorStrain check seems to make more sense than an EpsilonY check. Edited May 16, 2022 Link to comment Share on other sites More sharing options...
