[As...] Posted May 15, 2022 Share Posted May 15, 2022 Hello, I want to analyze a compact tension test result of DIC on rock samples. when I set calibrating scale and implement the surface component the resultant strain map is not satisfactory. my tested specimen includes a crack. I think different distribution of strain field are expected around the crack and especially at the crack tip, but my strain plots does not include them. I attached one frame of my result. is there any solution for this? or is there any missed procedure? thanks Link to comment https://qualityforum.zeiss.com/topic/949-strain-map/ Share on other sites More sharing options...
[Th...] Posted May 16, 2022 Share Posted May 16, 2022 (edited) Hi, your expectations are right - there should be some strain values at least over the crack. How does your stage 1 look like? Is it already cracked there or is it snapped from the unloaded specimen? How does the displacement field (check for Displacement or DisplacementX) look like? Anyway - for this kind of crack an EpsilonX or MajorStrain check seems to make more sense than an EpsilonY check. Edited May 16, 2022 Link to comment https://qualityforum.zeiss.com/topic/949-strain-map/#findComment-2937 Share on other sites More sharing options...
