profile tolerance zone
I have more questions. Does the print invoke ASME Y 14.5 ? It appears they were trying to communicate an unequally disposed tolerance.
I have questions concerning Datum mobility as well. What is Datum feature B ?
Also Profile doesn't require simultaneous condition by default, so technically you could meet each FCF independently. is not correct
See correction below
https://qualityforum.zeiss.com/topic/9546-profile-tolerance-zone/#findComment-44492
Under Y14.5 profile does have simultaneous requirements by default. 1132_623b80de4663e5df66efabf6796b2e4d.jpg
From Y14.5-2018, page 80. (apologies about the scaling). It goes on to say that if a simultaneous requirement is not required, to use a note such as "Sep. Req.", which emphasizes that this is the default behaviour.
ISO, however, does not require this by default.
I think the intent reasonably clear - it is equivalent to a profile with a tolerance of 1.8(U)0.3 to the same datum reference frame. If this is an asme drawing, I would consider it strange and ambiguous, to the point of being wrong, and contact the design authority for clarification if possible.
https://qualityforum.zeiss.com/topic/9546-profile-tolerance-zone/#findComment-44500
