[Wi...] Posted September 19, 2022 Share Posted September 19, 2022 Im trying to get an export to excel to link to our 3rd party CAQ.net software. However excel gives me a framework error when checking the box. I then tried to export from piweb to excel. However it doesn't bring in all the header data. Did anyone figure a way to change this directly out of piweb? Link to comment Share on other sites More sharing options...
[Ri...] Posted September 19, 2022 Share Posted September 19, 2022 Please sign in to view this quote. If you are exporting out of the PiWeb Reporting Database, make sure it is turned on to export attributes. Link to comment Share on other sites More sharing options...
[Wi...] Posted September 19, 2022 Author Share Posted September 19, 2022 Please sign in to view this quote. I've done it that way. But it is missing some user defined fields from the header data. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 19, 2022 Share Posted September 19, 2022 Please sign in to view this quote. Then they are not linked to PiWeb. You need to have them mapped. Link to comment Share on other sites More sharing options...
[Wi...] Posted September 19, 2022 Author Share Posted September 19, 2022 Please sign in to view this quote. This got me closer. Thank you! I now just have to figure out how to use the column instead of rows in CAQ. I was also able to make a custom txt file that I may be able to use in the mean time. Link to comment Share on other sites More sharing options...
