Cookbook Settings
Looking at the cook book on Perp and Axial Run out. CB says with perp to run the shaft as a lsq cylinder and plane as outer tang.
In regards to Axial RO it says use LSQ on the plane and use a GN cylinder for the datum.
Will I get a major difference if I use 2 circles and recall those into a 3D line and do the call-outs from the lines as opposed to using the cylinders in both measurements above??
https://qualityforum.zeiss.com/topic/9564-cookbook-settings/
A major difference? That will depend on the form of the features and where the part is probed. And what the tolerances are, etc.
From my experience recalling circle points into a cylinder will give different results than measuring as a cylinder. It's the geometry/vector difference between a circle and cylinder.
The differences in evaluation are suggested because the measurements essentially swap datums.
https://qualityforum.zeiss.com/topic/9564-cookbook-settings/#findComment-44578
