Position callout without datum
Dear K Zack,
Looks a little strange for me...
As no CZ is defined it means SZ by default. The modifier "30X" sould be written above the tolerance frame. And I miss the reference definition...
But you see: I´m not the expert in GPS but my hope is, that someone will correct me 🙂
regards
Karsten
If we take out strange definition, then meaning will be as author said - pattern.
To make it work just do this:
  • make normal pattern TP and fill features in it
  • check rotation and translation and click "Now calculate" and close windows
  • create new TP callout ( or copy previous )
  • here you can select pattern alignment. First TP callout can be masked and ignored from protocol
