[Ca...] Posted September 9, 2022 Share Posted September 9, 2022 Hello my friends, short question, does anyone of you know if its possible to evaluate MMC on a True Position of a Circle of Cone? Got a drawing where i need to measure a cone, which i mostley do with several Circle on Cone and evaluate the Position "0 / MMC to A-B" Im really not sure about, for sure with a circle it would work, as its not a big cone i could recall the circle on cone as a circle and use this position, but its not really what is requested and im not sure if the value would be corrupt. Any ideas? Thanks and regards, Link to comment https://qualityforum.zeiss.com/topic/9606-is-it-possible-to-use-mmc-on-a-true-position-of-a-cone-circle-on-cone/ Share on other sites More sharing options...
[Ke...] Posted September 9, 2022 Share Posted September 9, 2022 I would think that if the print calls out for a diameter of the cone at a specific height, then it shold be legal... can you post an example of the callout? Link to comment https://qualityforum.zeiss.com/topic/9606-is-it-possible-to-use-mmc-on-a-true-position-of-a-cone-circle-on-cone/#findComment-44828 Share on other sites More sharing options...
[Da...] Posted September 9, 2022 Share Posted September 9, 2022 Check the cone as a cone. Circle on a cone is not reliable. After checking the cone use cone calculation to ask for a diameter at a specific height. Now you can ask for position of the cone calculation. It has a diameter and you can assign a size tolerance. 😃 Link to comment https://qualityforum.zeiss.com/topic/9606-is-it-possible-to-use-mmc-on-a-true-position-of-a-cone-circle-on-cone/#findComment-44830 Share on other sites More sharing options...
[Ca...] Posted September 9, 2022 Author Share Posted September 9, 2022 Thank you very much for your support. 🙂 Cone addition works perfect, i was really not aware that when you use cone addition that you can then as for a MMC position but not from a cone or a cirle on a cone seperate. 🙂 Thank you, Link to comment https://qualityforum.zeiss.com/topic/9606-is-it-possible-to-use-mmc-on-a-true-position-of-a-cone-circle-on-cone/#findComment-44832 Share on other sites More sharing options...
