Freedom software
You can track usage via CMM Observer.
Open the XML file in Excel.
Follow default prompts.
And you will have a worksheet like the attached image.
In the PlanName column is the program name.
In the RunStart column you will have info like this:
2021-09-02T18:12:28.103062-04:00
The highlighted section is the start time.
The first part of the above string is the run date (2021-09-02)
In the RunEnd column:
2021-09-02T18:14:01.911062-04:00
In the RunDuration column is a decimal value, this can be converted to time for "hh:mm:ss"
All of this can be plotted within Excel.
https://qualityforum.zeiss.com/topic/9662-freedom-software/#findComment-45208
  • 4 months later...
