[Ri...] Posted January 31, 2020 Share Posted January 31, 2020 To get you on topic. In the drop down menu at the top of Calypso select "CAD" Then "Evaluation" This opens a dialog box named "Results Presentation" What is happening since installing Calypso v6.4.xx (now using v6.4.28) there is a CAD view being saved when editing Features and or Characteristics. This creates all these unwanted views which makes the model jump to all these different views every time you click on a feature or characteristic that had an automatic view saved. How can I stop this from happening and how can I mass delete these views?Untitled.jpg Link to comment https://qualityforum.zeiss.com/topic/9692-how-to-stop-auto-creating-cad-evaluation-views/ Share on other sites More sharing options...
[To...] Posted February 3, 2020 Share Posted February 3, 2020 I use this feature all the time and not aware of any "auto creation" option. Yes, when CAD Eval is on, you'll see points when you select a characteristic but it doesn't change the view. Can you provide any pics of other settings? Are you talking about this setting? Link to comment https://qualityforum.zeiss.com/topic/9692-how-to-stop-auto-creating-cad-evaluation-views/#findComment-45444 Share on other sites More sharing options...
[Ri...] Posted February 3, 2020 Author Share Posted February 3, 2020 This has been a problem on all five of our CMM's right from software installation. The fifth (Contura G2) was a new install on a new CMM.Untitled.jpg Link to comment https://qualityforum.zeiss.com/topic/9692-how-to-stop-auto-creating-cad-evaluation-views/#findComment-45446 Share on other sites More sharing options...
[Ri...] Posted February 4, 2020 Author Share Posted February 4, 2020 Other than what I provided, I don't know where to look. Its been a problem since install of v6.4.x Link to comment https://qualityforum.zeiss.com/topic/9692-how-to-stop-auto-creating-cad-evaluation-views/#findComment-45448 Share on other sites More sharing options...
[Ri...] Posted February 18, 2020 Author Share Posted February 18, 2020 There are times, particularity with Points that the CAD model will zoom out to some view automatically. If I do not manually go thru each characteristic to remove all the "views" flopping around the screen, operators get a bit nervous. They think something is wrong and slow down the speed via the Blue Box, which in-turn changes the feed of scans and subsequently changes the dynamics of the settings for specific feeds. Its a distracting nuisance... 😕 Link to comment https://qualityforum.zeiss.com/topic/9692-how-to-stop-auto-creating-cad-evaluation-views/#findComment-45450 Share on other sites More sharing options...
[Ri...] Posted May 12, 2020 Author Share Posted May 12, 2020 viewtopic.php?f=13&t=2749 Link to comment https://qualityforum.zeiss.com/topic/9692-how-to-stop-auto-creating-cad-evaluation-views/#findComment-45452 Share on other sites More sharing options...
[Ri...] Posted August 29, 2022 Author Share Posted August 29, 2022 Although I don't have definitive proof, I believe this is all due to "Stylus changes" and or "rotating the stylus (RDS)". In most instances with a VAST head, a new stylus selection from the drop down seems to generate a CAD view. With RDS heads, we all know the view zooms out to show the column and RDS head, which I also believe generates a CAD view. These CAD views are dependent on your view at hand when you make a selection (VAST or RDS). Link to comment https://qualityforum.zeiss.com/topic/9692-how-to-stop-auto-creating-cad-evaluation-views/#findComment-45454 Share on other sites More sharing options...
