[Da...] Posted August 26, 2022 Share Posted August 26, 2022 I want to check a part 5 times and get a diameter each time I check it. I tried looping , but I only get one diameter. I don't have pcm, and ( other than looping a base alignment ) I don't have much experience with the loop function. Any help would be appreciated ! Link to comment https://qualityforum.zeiss.com/topic/9694-loop-help/ Share on other sites More sharing options...
[To...] Posted August 26, 2022 Share Posted August 26, 2022 Create a linear pattern on the circle and have 0 as the distance and 5 as the quantity. Alternatively, right click in characteristics window with nothing selected and click loop. Change end to 5. This will run the entire program 5 times Link to comment https://qualityforum.zeiss.com/topic/9694-loop-help/#findComment-45458 Share on other sites More sharing options...
[Da...] Posted August 26, 2022 Author Share Posted August 26, 2022 I am running a probe qualification feature between circle checks. When I looped it only produced one number, I am looking for 5 numbers. Link to comment https://qualityforum.zeiss.com/topic/9694-loop-help/#findComment-45460 Share on other sites More sharing options...
[Ju...] Posted August 26, 2022 Share Posted August 26, 2022 Could you copy the feature five times and have a characteristic for each feature? Link to comment https://qualityforum.zeiss.com/topic/9694-loop-help/#findComment-45462 Share on other sites More sharing options...
[Da...] Posted August 26, 2022 Author Share Posted August 26, 2022 I was hoping a loop would work, but I guess that's what I'll do. Thanks Guy's Link to comment https://qualityforum.zeiss.com/topic/9694-loop-help/#findComment-45464 Share on other sites More sharing options...
[To...] Posted August 27, 2022 Share Posted August 27, 2022 Please sign in to view this quote. Ignoring that you added a probe qualification to the problem, are you saying this didn't work? "Create a linear pattern on the circle and have 0 as the distance and 5 as the quantity." Feature: Circle1(5) Characteristic: Diameter_Circle1(1,5,1) Link to comment https://qualityforum.zeiss.com/topic/9694-loop-help/#findComment-45466 Share on other sites More sharing options...
[Da...] Posted August 29, 2022 Author Share Posted August 29, 2022 I did not try the linear pattern, but I am sure it would work. Very creative ! Link to comment https://qualityforum.zeiss.com/topic/9694-loop-help/#findComment-45468 Share on other sites More sharing options...
