PC-DMIS Import/Export
You don't necessarily need a CMM with PC-DMIS, you need a licensed copy of PC-DMIS installed.
However, you can read PC-DMIS as a text file, you should be able to duplicate the program. You would have to understand PC-DMIS commands, which is not to difficult.
Hello,
I wrote a Knowledge Base article on this topic. Feel free to check it out!!
FAQ:
      - You have to have Calypso and Pcdmis on the same pc
      - It is a paid option so you would need to contact your Zeiss Aftermarket Sales Rep
      - As with any translator, you will need to "clean things up" after conversion
If Calypso and Pcdmis are not on the same system, the other route would be to export dmis out of Pcdmis and
Dmis import into Calypso.
  • 4 months later...
HI Daniel,
If you are exporting from PC-DMIS, this question would be best directed to the PC-DMIS Importer team at Hexagon. From the Calypso perspective, our typical process is to open the feature strategy, remove the existing probing points, and then apply a scan strategy.
For more detailed information regarding the PC-DMIS to Calypso import process, please refer to the Knowledge Base section of the ZEISS Portal.
