Tactile Optical Alignment - PCM error?
Hey all,
I recently upgraded to 2021 - 7.2.08 (21.02.2022), and I am having trouble with the tactile-optical alignment program (tactile_optical_adjustment_and_check_V2.2_C5.8). When I run it, it does the tactile section fine, but as soon as it starts the optical section, it gives this error. "Message not understood: #asPointArray"
Has anyone seen this before?
I don't have a copy of the 5.4 one - any chance you could send me one? I will PM you my email, if that works?
So the solution the hotline provided was to use the most recent version of the program: "tactile_optical_adjustment_and_check_V4.0_C7.2".
Richard - thanks very much for providing the old program version - it didn't fix the issue.
David,
Did they send this measurement plan to you because it is not installed with the Measurement Plan Examples.
Hi David,
Thank you for that. I've been hearing about this new measurement plan, but I've been confused as to why it isn't part of the measurement plan examples install.
