Straightness of an axis
You're still at straightness of an axis. You don't need to smooth the derived median line to evaluate the straightness. The full form error must be evaluated.
But other than for straightness evaluation the derived median line is also used to define the direction of the local sizes. If you have a derived median line that is not "tangent continuous", you will run into a problem, because you can't make a perpendicular local size at the imperfect parts of the line. See my attachment for what a tangent continuous line is.
If the derived median line is not tangent continuous, you have to smoothen the line to calculate a local size direction even at those places of the line that are flawed.
That's all there is. So, in answer to your straightness #1 vs. #2, why do you need a smoothed line: You don't, and I never said you do. Not for straightness, only for local sizes!
If I could make drawings half as good as you, I would have made one already. Hope you still understand what I mean.
Dok4.pdf
