Adding serial number in excel report
Hi,
I have necessity to put in excel report file name the serial number in addition to the progressive number generated automatically by calypso.
I would also have the need to add the serial number inside the header of excel report but I don't know how I do to modify the header of template.
Thanks
Thank you for the files.
The second file explain very well. But I have a question about the report's header.
For summarize. The first step is to edit the report INI to add personalized records. The second step is edit the char file adding new record, but is it possible to write manually directly in excel’s cells? I would like add in the report's header the serial number. I add this number before run program in Calypso
I know it can be done by editing the xxx userfields or with PCM or through the piweb report but, I'm out of time today to get too specific and probably won't have much time tomorrow.
I've attached a very old guide that should still work (?) on how to add the Workpiece Serial number to the input parameters in a window that can be forced to automatically open when the program is started and also can be added to the header.
Hopefully somebody else will add the details if you have any problems.
Good luck.
Calypso Printout Header Variables with userfields.docx
This morning I have modified the userfield file and the report ini. I Have added my personalized fields in the protocol's header in characteristics file. When I run a cycle in calypso, excel go into error.
See attached files
885D419E-67DD-4046-8EA5-998BF1C5AE84.jpeg3A36557C-EE3A-4554-879F-1DEBF0269C96.jpeg1E19C532-E4D6-4A02-BE31-F0C71CFB7D1F.jpeg43D56A22-3F95-4C8D-89FE-B70E6BC177AE.jpeg7862BFA4-9075-4E4D-9F97-BD4F5CA7331A.jpeg299C4F61-048F-4C04-8789-C81262026923.jpeg
Thanks but I don't have the pcm's license.
I want to edit the excel template to add my personalized fields (work order and serial number) in the report header.
I need these fields to post-process reports to prepare customer's documents.
