Curve Point Data
There is a nice quick way - Under Resources -> results to file. You can choose whether you want it as txt data, or as a DXP, or some other options.
There is an option to turn on Curve data exporting, you can choose a myriad of ways to get the data. All the data will go to a folder under results (wherever you had set it up under Extras -> Settings -> Environment -> Paths )
See the attached snip for some more details.
Curve Point.JPGFetching info...
Hello,
Please describe exactly what's your reqiurement
- Nominal or Actual?
- Measured points or the actual related to the according nominal?
- Handle the complete files or each pair (nominal,actual) single?
- What should be done with the output (external or internal processing)?
Thanks
We are running tests on gears and checking for wear after running them thru a test cycle.
We just need to know the distance each point has moved from nominal.
we ran the parts as received and are re running them after the test to check the wear and would like to put the data in a file such as excel to compare the difference.
Thanks,
I prefer to use the homolgous points
No-Nominal = 500
No-Actual = 750
homologous Actual = nom(i)+dev(i)
dev(i) = devialion with sign and filter are possible. Outlier not active, because if active, the nominal will be masked.
Will be fixed, I think inside CALYPSO 2020
=> no of nominal == no of actual
Look a inspection and attached EXCEL, numericals are identical
[/attachment]1828_4bf31a439d9febcc16284071d36e7557.png
Gear_Curve_Export.zipFetching info...
