[Cl...] Posted April 23, 2021 Share Posted April 23, 2021 Is there a way to somehow add a picture inside the Measurement Plan Comment? Maybe with PCM? Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/ Share on other sites More sharing options...
[Al...] Posted April 23, 2021 Share Posted April 23, 2021 what is the purpose? Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66076 Share on other sites More sharing options...
[Cl...] Posted April 23, 2021 Author Share Posted April 23, 2021 In autorun it would display a picture without having to manually open one up. Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66078 Share on other sites More sharing options...
[To...] Posted April 23, 2021 Share Posted April 23, 2021 Search help for "external batch files" Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66080 Share on other sites More sharing options...
[Ri...] Posted April 23, 2021 Share Posted April 23, 2021 Please sign in to view this quote. In 2018+ you have the option to automatically open the User Information file when clicking on Run. Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66082 Share on other sites More sharing options...
[Ma...] Posted April 23, 2021 Share Posted April 23, 2021 I think I've used this before.Calypso - User_Info_batch_files_inst.pdf Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66084 Share on other sites More sharing options...
[Ma...] Posted April 23, 2021 Share Posted April 23, 2021 Please sign in to view this quote. ...or maybe it was this 🤣Add User_Information_startup.pptx Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66086 Share on other sites More sharing options...
[Ro...] Posted April 26, 2021 Share Posted April 26, 2021 Ive been messing around with this for a while, and i cant get MS Photo which is my default photo viewer to launch right, but i did stumble on a usable glitch, it works just good enough for me to not search for a better way. Open a batch file, if you need one i can probably attach one, but i think manually changing a .TXT file to .BAT will work. start "ms-photo" "C:\Temp\Picture.jpg" This command will open a picture in MS PAINT, not picture. Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66088 Share on other sites More sharing options...
[Cl...] Posted April 26, 2021 Author Share Posted April 26, 2021 Thanks everyone, good stuff! Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66090 Share on other sites More sharing options...
[Mi...] Posted April 26, 2021 Share Posted April 26, 2021 systemCallWithWait() You can use this to force open a file. Put it in the presettings to your program, pick your photo viewer of choice, in our case Irfan View ( it's very light, opens faster than windows photo viewer) systemCallWithWait("C:\Program Files\IrfanView\i_view64.exe " +chr(34)+ getActualInspectionDir() + "\Loading.jpg"+chr(34)) So this goes to the program files and opens Irfan View, and the loading instruction photo that we save in the program directory, called "Loading.jpg". Our programs get moved machine to machine to it ends up being far easier to have the photo just as part of the measurement plan folder than having a separate photo library on each computer as we used to have. To be extra modular we have that code in the inspection_start_pcm.txt file so it controls every program on the CMM, regardless of version. Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66092 Share on other sites More sharing options...
[Ju...] Posted April 27, 2021 Share Posted April 27, 2021 I hope this helps. Go to PLAN/MEASUREMENT RUN INFO FOR CNC START/SELECT then find your downloaded picture and load. I always write a comment in the measurement plan comment box as a reminder to click on user information tab to see the loaded picture of set up. Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66094 Share on other sites More sharing options...
[Cl...] Posted April 27, 2021 Author Share Posted April 27, 2021 I do that already. I would like the picture to display in the Measurement Plan Comment box above User Information in autorun. That way the operators have no excuse about how to load/set-up the part. Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66096 Share on other sites More sharing options...
[Ri...] Posted April 27, 2021 Share Posted April 27, 2021 Please sign in to view this quote. I commented earlier that you can force the User Information to open every time the measurement plan is executed. In addition, if it's just a simple picture, I like to have that as the icon image for that measurement plan. Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66098 Share on other sites More sharing options...
[Ro...] Posted April 27, 2021 Share Posted April 27, 2021 Please sign in to view this quote. So a couple suggestions for autorun. as long as the picture doesn't need to be very detailed, say in order to get the operators to use one of two very different fixtures. Save a picture as "icon.bmp" and drop it in the inspection folder of the part you are checking, the picture will automatically show in the upper left corner of the run window (see picture). As for autorun pictures, save a picture and drop it in the inspection folder named "inspict.bmp", make sure it cropped very square, it will automatically load as the icon image when you open it in autorun.sfdfdfdghghjhjhkkjkl.JPGjhkljhkjhfgdrgdtdghghjh.JPG Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66100 Share on other sites More sharing options...
[Te...] Posted April 27, 2021 Share Posted April 27, 2021 Here is how I imbed a pdf instruction into my calypso programs. The wording to select the file has changed in newer versions of the software to Plan / Measurement Run info for CNC Start, (guide needs to be updated) in AutoRun if the instructions are here they will pop up every time if you click the box in the CNC window of the pallet or program icon for Force Measurement Run Information at CNC Start. No PCM or anything needed.Creating User Information.pdf Link to comment https://qualityforum.zeiss.com/topic/13042-measurement-plan-comment/#findComment-66102 Share on other sites More sharing options...
