[Wo...] Posted June 4 Author Share Posted June 4 Question to people who have installed 8.0 on their machines: When measuring the part, I have a delay of sometimes even 3 seconds after each feature measured. I'm suspecting it takes this long to "save" measurement points somewhere. I don't have this delay on 7.8. Anyone else experiencing this? 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted June 24 Share Posted June 24 Hello Wojciech I have the exact same problem. I found that when the clearence plane is activated makes the registration of features extremely slow. If you set the clearence plane to zero, as if it hasn't been set yet, features will be recognized fast as in 7.8 3 Link to comment Share on other sites More sharing options...
[Ch...] Posted June 24 Share Posted June 24 Please sign in to view this quote. I'll telling you guys, Zeiss changed something in the background with clearance planes ever since service pack 7.8.12. See my post: Blank clearance planes giving error after installing service pack 7.8.12 and also in Calypso 8.0 3 Link to comment Share on other sites More sharing options...
[Ma...] Posted June 25 Share Posted June 25 We have a second CMM in our lab with 8.0 installed - basic install - no add on's - works fine, no lag My machine has the profiler and surface package installed too - No problem in 7.8 - big lag in 8.0 Don't know if if it could be related to the add on packages. Our local Zeiss support has been informed of this lag. 2 Link to comment Share on other sites More sharing options...
[Wo...] Posted June 25 Author Share Posted June 25 Please sign in to view this quote. I don't have time this week, but next week I'll install 8.0 on the CMM that doesn't have curve or freeform and see if there's any difference. Thanks! 2 Link to comment Share on other sites More sharing options...
[Ro...] Posted June 26 Share Posted June 26 New patch and simulation for Centermax is still broken. 🤦♂️ 2 Link to comment Share on other sites More sharing options...
[Ma...] Posted July 1 Share Posted July 1 Please sign in to view this quote. Hi Wojciech I was just contacted by my local Zeiss support. They are on the case, and wanted a screen dump on the firmware of my machine. The firmware on my machine, which lags, is V31.22. with RDS probe installed The other machine, which works, has V31.23 with VastXT probe installed. You can find your firmware version under Extras - Error report May be firmware related - I'll keep you updated. 1 Link to comment Share on other sites More sharing options...
[Je...] Posted July 1 Share Posted July 1 Please sign in to view this quote. Patches are "full" installs now without external dependencies (like C++ Redistributables, drivers, secondary models etc). Service Packs are complete installs, same as "Base Version". Base version is no longer necessary to install once a Service Pack is available (as of release of 7.8.12 and newer) Please sign in to view this quote. I would also review your network use. Are you running programs off a network? Storing "actuals" on network (this is a big no-no) Please sign in to view this quote. Look for fixes in Service Pack releases. You will likely not see a simulation fix in a Patch (Patches are not tested to the same standard as Service Packs and are focused on high-priority bugs). Simulation bugs are not generally patch resolved as it does not affect real-time machine related measurement. 2 Link to comment Share on other sites More sharing options...
[Je...] Posted July 1 Share Posted July 1 Please sign in to view this username. That was a very useful improvement. It will likely provide increased stability after installs. Link to comment Share on other sites More sharing options...
[Wo...] Posted July 3 Author Share Posted July 3 Please sign in to view this quote. I don't think network is an issue. I have the programs running from the same network on both 7.8 and 8.0 machines and and 7.8 doesn't have slowdowns. Also, the machines that have 8.0 did not have slowdowns on 7.8. I've installed 8.0 on one machine and noticed the slowdown. I was curious if its specific to this one machine so I installed 8.0 on the other machine - slowdowns appeared immediately. To test, I've copied some plans to the desktop and run from there - the machine was still "thinking" for a few seconds before starting the run - noticeably longer than on 7.8. Please sign in to view this quote. 7.8.12 was working fine for me in terms of speed, can't tell you anything about blank clearance planes, sorry. Please sign in to view this quote. Thanks for the updates! I'm not sure if its firmware related as one of the machines is pretty new from 2023 and the other is from 2017 and both show the issue. I will try to install 8.0 on a machine from 2011 to see if there is a difference. Thanks for the help! Link to comment Share on other sites More sharing options...
[Ma...] Posted Friday at 05:28 AM Share Posted Friday at 05:28 AM Please sign in to view this quote. Are the machines you have trouble with installed with RDS heads? My machine has RDS head installed and is slow. Our other machine has a VASTXT head and has no problem. 1 Link to comment Share on other sites More sharing options...
[Wo...] Posted 13 hours ago Author Share Posted 13 hours ago Please sign in to view this quote. Both machines have VAST XTR so maybe the possible rotation is the issue? I will have to install it on the machine with XT only. Thanks! 1 Link to comment Share on other sites More sharing options...
