[Wo...] Posted October 30, 2025 Author Share Posted October 30, 2025 So I've downloaded a new Service pack (8.0.08), but the installation fails with an error that some files are missing. Now I see that the download is taken down. Bad upload on Zeiss' side maybe? Link to comment Share on other sites More sharing options...
[Sv...] Posted October 31, 2025 Share Posted October 31, 2025 I was able to download and install the service pack just now. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted October 31, 2025 Share Posted October 31, 2025 Me too - no problems during the install Link to comment Share on other sites More sharing options...
[Wo...] Posted October 31, 2025 Author Share Posted October 31, 2025 Please sign in to view this quote. Please sign in to view this quote. Looks like it was re-uploaded - downloading now 😉 Link to comment Share on other sites More sharing options...
Popular Post [Ch...] Posted October 31, 2025 Popular Post Share Posted October 31, 2025 Holy Hotdogs, it actually fixed my simulation seat. I'm not saying I didn't have any confidence in Zeiss to get it fixed but I really didn't have any confidence they would fix it. 7 Link to comment Share on other sites More sharing options...
[Wo...] Posted October 31, 2025 Author Share Posted October 31, 2025 Please sign in to view this quote. Didn't have time to really test it out, but it looks good, even the XTR rotation works - first time in years. Had some issues though, some probes were far away from the workpiece, like they've had a bigger diameter than the CAD showed. They have a correct one though, so I'm not sure what's up. I've created a machine from scratch to avoid any import problems. Also for some reason, during simulation, the button to display probe only is greyed out. Performance-wise its great. Link to comment Share on other sites More sharing options...
[Jo...] Posted November 1, 2025 Share Posted November 1, 2025 My simulation seems to be behaving now too! Link to comment Share on other sites More sharing options...
[Te...] Posted November 3, 2025 Share Posted November 3, 2025 My Simulation is better but it is still slow but at least it is passable. I have used a new config file to see if that help and double checked the NVidia settings and it still a little funny it is not smooth. I even may sure I restarted the PC. May call Zeiss this week and see if they can help 2025-11-03 11-52-42.mp4 Link to comment Share on other sites More sharing options...
[Ch...] Posted November 3, 2025 Share Posted November 3, 2025 (8.0.08) simulation still unuseable for me. Link to comment Share on other sites More sharing options...
[Ka...] Posted November 6, 2025 Share Posted November 6, 2025 Just a hint... If you install 8.0 the current SQL server version from Microsoft will be overwritten without any hint or warning. If you run a 7.4 on the same physical machine you will get some trouble after reboot. The 7.4. will not start again cause the new SQL server version is started by 7.4. I got the messages that the probe Db will not be find or is corrupt.... You have to reinstall 7.4 using "repair mode" to fix it 😞 If 8.0 is running after this I don´t know. Never ever start 8.0 again on my productive offline station.. 1 Link to comment Share on other sites More sharing options...
[Ja...] Posted November 6, 2025 Share Posted November 6, 2025 Installed the latest service pack. Simulation is still so slow I thought it froze up at first. Unusable. 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted November 6, 2025 Share Posted November 6, 2025 Not sure if this will help you guys or not, but my old computer fried right before the service pack came out. I lost all my setup info and had to make all my machine tabs from scratch. I even had my programmers in training make new styli in SSC and used the new SSC probes. I didn't use anything from before. Is it possible that making new machine tabs and everything else from scratch might help? Just a thought. My simulation seat is humming along just fine since the new service pack. Link to comment Share on other sites More sharing options...
[Ja...] Posted November 6, 2025 Share Posted November 6, 2025 The way our network is set up, I don’t think it would help to make all new stylus systems in SSC. There’s no connection between the files and the seat so there wouldn’t be a way for them to get corrupted. But I could see how setting up a new tab and re-importing them might make a difference. Definitely food for thought. I’m just hesitant to do it because it would be a real pain in the posterior importing 5 dozen stylus systems. Just might have to grin and bear it and try it anyway. Thanks for the idea. Link to comment Share on other sites More sharing options...
[Sh...] Posted November 7, 2025 Share Posted November 7, 2025 The latest service pack 8.0.08 has a glitch with the ZAS head. Zeiss Germany is now aware of the issue but if any of you use it in Planner, I suggest holding off until they release a new patch or pack because it leads into the ole SDCO error and then your machine is toast. 1 Link to comment Share on other sites More sharing options...
[No...] Posted November 10, 2025 Share Posted November 10, 2025 Today I finally got around to installing Calypso 2025 (latest SP 8.0.08) and up to now I can't complain about Simulation at all. On the contrary, it's much faster than in previous releases, even on the lowest speed setting. So fast indeed that I was concerned it wouldn't detect collisions at travel speed as reliably as before. But even that worked very well in my first tests. I also see a slight stop'n'go behavior like in Ted's video, but it's much more subtle (may have to do with the speed setting - I always simulate on lowest speed). So far I'm impressed. But then our models might be far less complex than those of others. Link to comment Share on other sites More sharing options...
[No...] Posted November 10, 2025 Share Posted November 10, 2025 Small complaint: Simulation doesn't keep its settings, like speed, show/hide CMM, show collision warnings, transparency... Fix please 🧐 2 Link to comment Share on other sites More sharing options...
[Ja...] Posted November 13, 2025 Share Posted November 13, 2025 Follow up to slow simulation problem - Set up a whole new machine tab, but alas, it's still as slow as snails. Installed the latest patch and that didn't help either. I'm curious as to how many people are still suffering with slow simulation. Link to comment Share on other sites More sharing options...
[Te...] Posted December 1, 2025 Share Posted December 1, 2025 Follow up on Simulation, when I wiped out the conf file and created a new one simulation worked much better it is still no where near as fast as it use to be and running it with the slider all the way to the right actual made it worse so slow to middle seem to work OK Link to comment Share on other sites More sharing options...
[Vo...] Posted January 26 Share Posted January 26 Hallo, mich würde mal interessieren, wann die ganzen kleinen Bugs in Calypso 8.0 beseitigt werden, meine hier nicht den Planner. Ein Beispiel bei Menü Bearbeiten alles markieren werden nicht alle Messelemente angezeigt, Bei Anwahl (RDS) Taster auf Position drehen wird kein RDS mit Taster mehr angezeigt, bei Anwahl Messelement, Strategie wird diese nicht angezeigt usw. Das ganze ist bestimmt kein Drama aber es nervt das ich jedes mal wieder zu Calypso 7.8 zurück wechsel, denn da funktioniert erstaunlicher weise alles Link to comment Share on other sites More sharing options...
[Ka...] Posted January 26 Share Posted January 26 Moin Volker, In einer Videokonferenz letzte Woche wurde schon CALYPSO 8.4 angepriesen.... Da soll die GDT dann auch aus dem Beta-Status raus sein; wobei ich dachte das dies in 8.0 auch schon so 🙂 Gesehen habe ich die korrekte Unterstützung der neue DIN EN ISO 5459:2025-12 was richtig klasse ist. Also wir werden auf 8.4 warten (8.2 wird´s dann wohl nicht geben?? ) bevor wir ernsthaft über einen Wechsel nachdenken. Vielleicht hat der Planner es bis dahin auch geschafft oder ist konsequenterweise komplett aus dem Protfolio herausgeflogen. 1 Link to comment Share on other sites More sharing options...
[Wo...] Posted February 25 Author Share Posted February 25 PSA: Service Pack 8.0.12 just dropped. Downloading now, will see if I can import SSC correctly in it. 1 Link to comment Share on other sites More sharing options...
[Ro...] Posted May 6 Share Posted May 6 (edited) I just tried importing an SSC file, for an XTR stylus system, and I get an error every time. It is sad that 8.0 is still so broken. Edit: Created a machine from scratch, after more unhandled exception errors and software restarts, and the import worked, but the Z values from my PCF not so much. I guess I need to rebuild all of my machines from scratch, for 8.0. Edit #2: Very next one gave same error. Apparently it doesn't like ConturaXTR for the name. ConturaXTR1, it works. 🤦♂️ Edited May 6 2 Link to comment Share on other sites More sharing options...
[Wo...] Posted Tuesday at 03:34 PM Author Share Posted Tuesday at 03:34 PM Just FYI a new service pack just dropped and it looks like there are several fixes for simulation. Downloading now! 1 1 Link to comment Share on other sites More sharing options...
[Ka...] Posted Thursday at 08:40 AM Share Posted Thursday at 08:40 AM Please sign in to view this quote. Whether this is actually a major functional breakthrough...?? The main problems were performance, 3D models of all CMMs, 100% detection of all collisions, measurement range overshoot with RDS XXT, memory leaks, and a whole host of other issues. From Release notes of 8.0.16: 795786 In the CAD simulation, collision detection is now set to very high accuracy by default. 803828/809372 Curve with a turntable. In the CAD simulation, the turntable is rotating in the wrong direction 817080 CAD simulation. Contura G2 does not work directly with XXT. 818704 The wrong stylus is displayed in the CAD simulation. If a stylus system is present, it will be displayed; otherwise, the (stored) reference stylus system is displayed. 823312 URDF files and the faceting of the button simulation have been revised. The display and performance of the CAD simulation have been improved. 862756 The CAD simulation does not work properly if file paths contain special characters, such as the sharp S (ß). 863099 An incorrect position in the CAD simulation during the calculation of the measurement range in the Z-direction has been corrected. 867088 The Prismo 16/24/10 was not displayed correctly in the CAD simulation 1 Link to comment Share on other sites More sharing options...
[Wo...] Posted 6 hours ago Author Share Posted 6 hours ago Please sign in to view this quote. I doubt it's very drastic improvement. For me, the simulation was doing OK for a while (since .08 I think?), at least performance-wise. My biggest issue is that I can't import styli from the creator properly. Let's say I have a stylus with 5 probes set-up with creator, numbered, named and everything. When I import, it just shows a styli with name "0" and some random number, and just one of the probes. Visually on CAD the probes are there, but somehow Calypso doesn't have their data. It's weird. Link to comment Share on other sites More sharing options...
